What if there were just blocks aliases but a plugin let you assign them programmatically to selected blocks?
For example:
- Foo
alias:: [[Foo]]
- Qux
alias:: [[Foo/Qux]]
- Bar
alias:: [[Bar]]
- Qux
alias:: [[Bar/Qux]]
For example:
- Foo
alias:: [[Foo]]
- Qux
alias:: [[Foo/Qux]]
- Bar
alias:: [[Bar]]
- Qux
alias:: [[Bar/Qux]]
Hmm not too excited about this
. This looks a bit redundant and mixes page and block entity.
I think, easiest approach is to just gradually let each UI feature adapt more to block-level scope. And make block references ((1234)) more powerful. Then nothing new needs to be learned or changed by users.
Understood and I see why you want to use blocksâ tree structure to reference blocks. It would also make sense to be able to refer to specific children with a relative path.
My proposal of using aliases is basically use them as ad-hoc bridges from the strict namespace of pages to the fluid structure of blocks.
It could also be used in place of my previous idea of using title:: property, with the advantage that the user already know aliases. It would work like this:
alias:: Block 1
[[Block 1]]<[[Block 1]] as a property value[[Block 1]]
[[Block 1]] you will be pointed to that block instead of a pageI think this could at least unlock the Tana-like workflow, making us free to use nodes that are not pages/root blocks/MD files and that are in a tree structure.
I donât have better ideas than programmatically assign aliases using maybe a plugin to emulate what you want, sorry.
But maybe we could have a syntax like ((./Title)) that could let us point to a child block, though the the user would take care of not breaking links.
Something like:
- Title of an article
references:: ((./References))
- References
So that if this block appears as a result in a query table, you can click on References to go directly to its child block.
Though this could be done just using manually the block aliases mentioned above.
Your solution might work as short-term workaround, but will create technical debt for the app (my opinion).
The fundamental issue is unneeded discrimination between page and block on a UI and core logic level .
The described errors in OP are a manifestation of this design limitation. And our proposals/features could probably be implemented way easier, if blocks and pages wouldnât be distinguished this much in the UI.
I hope developers get more attention on this, to ease up further development and make it a strong competitor to Tana feature-wise.
Block aliases or not, the fundamental issue is:
The first point is a constraint of the file system (unique names). The second is a constraint for the domain logic (unique block IDs). This might be done by assigning an UUID to every block, incl. root block (=page), so there is a mapping of page name to page UUID.
What about an id:: property at the top of every page, akin to tags::, same as current block ids?
Alternatively we could use string ID and keep uniqueness of pages via filename, but that probably has performance issues.
Yes. + Showing block references in the âLinked Referencesâ widget at each page bottom would be quite useful.
No, this is the key, you think we have pages because of files on the file system, while we have pages because we want [[wikilinks]] i.e. we want to turn words in our paragraphs into references by simply adding []. Storing pages as files is a consequence, not a cause.
Now I understand while you brought the file system in this discussionâŚ
Logseq is not constrained by the file system at all and it already abstracts it away with its DB.
I hope now you understand why I proposed block aliases, because we would be able to define a new node from context instead of creating a new page.
Think more about it, block aliases are all we need: if you want a block to be treated like a page, assign an alias and use that as [[handle]] in properties and queries.
Good hint, seeing your point with âjust quickly typing itâ, for example as well with an external editor. But I am asking myself if this a contradiction at all. [[ ]] could be the syntax for uniquely named blocks, (( )) for blocks with possible duplicate titles and needed technical ID - no change again.
What has become more clear and important to me - and I think we both agree on this - , is that Query, Linked references + filter and all these great UI features in Logseq need to work on block-scope. And they should behave consistently (take page-tags/tags: for example), no matter if we keep pages or not.
Yes and they choose to call those named blocks âpagesâ⌠but the issue is that pages can only be root blocks (and this is what block aliases are meant to fix) and that they enable different features in the UI (just because devs decided to do so).
Yes and I have an idea on how block references (with ((UUID)) and [[aliases]] ) could be presented:
Additionally, I hope that devs will hear the suggestion I made to the designer about replacing Linked and Unlinked References sections with fixed queries where you can add additional filters with the future query builder.
So basically reuse UI components as much as possible.
As said, I am not a fan of this idea:
extends relations if you will with object oriented programming). There should be no need to artificially promote a block to page, if most of the logic operates on block as common type.Interesting idea, I like it.
If everything internally uses queries, that would reduce our block-scope issue to ⌠queries, hence more easy to fix
Iâd like to have some customizable footer for pages as well, where you can place more queries - similar to :default-queries in the journal.
And we havenât spoken of transitive queries yet. John Doe -> Author -> Person. Then on page Person query everything which is transitively linked, like page John Doe. That as custom query at page bottom would be cool.
I am out for today. Cheers!
(*) thanks again for your point, this indeed is important for easy typing links in the editor. Even if Logseq provides auto-complete for page IDs like [%title%](<page-id), creating links in an external editor would be more difficult. Btw: Havenât we already spoken of this with regards to blocks and their titles?
Personally I would only show those (un)linked references when you zoom into a block (as it is only referenced to that specific block) and not the larger set of blocks (aka page). A small indicator to indicate that there are references to this block in the first place is fine.
UPDATE : I wrote to soon
⌠seeing you next bullet. But I do not like the expanded show when not being zoomed in into the block.
To be clear, when not âzoomedâ it would look just as it is now, but:
The difference is due to the nature of file storage (& performance limitation)
Hopefully the database-based storage can remove the barrier. Itâs under development.
I think the concept of âpagesâ comes from the need to have references using [[words]] and saving them as files is a consequence (but not strictly needed).
Even with a different storage method, I donât think the concept of pages (and [[wikilinks]]) will cease to exist but correct me if I am wrong.
On the other hand what started this discussion is more about differences in UI/UX for pages and blocks that appear arbitrary, than a need to remove the distinction between pages and blocks.
(Edit: for example the issue reported by OP is about Simple Queries looking for references in block content and path, but not considering page-tags:: values too, that is something that would definitely makes sense from the user point of view).
@venture-comp let me stress again that the term âunifyâ in the title is misleading, what you are looking for is more consistency.
âMakes pages and blocks more consistentâ looks like a better title to me, that reflects whatâs discussed here.
Thanks for the info!
I have noticed the post has been marked with âestimate-very-largeâ, which is fair enough. Do you think the main described issues #7592 and #7978 can be fixed sooner - or are they are out of scope and we need to wait for database design first?
@alex0 it makes more sense then to mark OP as solved with this post I guess.
The two issues seem to be more complex to change than I hoped
. Developersâ statement:
It requires large effort due to the inner implementation of query
Feeling inclined to say: Only use block properties for now.
Omit any page-properties including tags::, if you need to search for multiple page references in a consistent manner with queries and filter widget.
I am currently testing a smallish Python script, which auto-converts all page-properties to block-properties. Disadvantage: There is an additional indention inside the page (for block inheritance). Advantage: searching and filtering works. Let me know, if there is any interest for discussions.
I have not this issue because I use page properties only to find pages.
Instead in pages I use [[references]] in section headers and below I place the content.
If you are looking for a workaround try to ask for an Advanced Query in queries on Discord.
Recently I got a query that looks for properties in parents (basically how [[references]] appear to be âinheritedâ by children, but for properties).
This is basically the behavior you are looking for but for pages (because with pages you are forced to use properties).
Interesting. Guess that is the beauty of Logseq - everyone has own, unique workflows.
I heavily rely on combining pages for quick searching, like [[logseq]] and [[feature]]. That might be a simple query (and [[logseq]] [[feature]] ). But youâve got a problem, if any of these links are declared as page tags:
(and [[logseq]] [[feature]] ) ?(and (page-tags [[logseq]]) [[feature]] ) ?(and (page-tags [[feature]]) [[logseq]] ) .Same with the filter - not predictable at all. You canât be sure to not have missed a result.
I know, advanced queries take it to another level. But that all is too cumbersome. I yet have to find an app that can create links and pages easiert than Logseq - [[foo]] is all it takes. If something is intuitive, quick and simple to do, you enjoy doing it more often. Same would be nice for searches and filter.
Your proposed query wizard certainly seems to be a good compromise. In the end, there is still a flaw in the current query implementation we should fix, so everything works consistently. E.g. a query builder doesnât help for the UI filter, or if you are already used to do your stuff with simple queries etc.
I understand your need, but on the other hand it is very natural to do so:
Logseq.md
type:: [[Application]]
tags:: [[PKM]]
- [[Features]]
- [[Plugins]]
{{query (page-tags [[PKM]])}}
{{query (and [[Logseq]] [[Features]])}}
This may feel natural to you, but is not my exact workflow.
Natural is to have freedom of choice how to organize things, without surprises.
Assuming we would organize notes like in your example with a template, even then it would be hard to keep notes consistent.
(Edit) Regarding example: At one point in the future, youâd like to find out content about PKM features and search for {{query (and [[PKM]] [[Features]])}}. Nothing found, if you canât remember, that PKM is a page tag - ouch.
