Is there a way to implement foldable embedded pages using custom CSS?
I aim to categorize pages saved as separate files into two main types: sticky notes and idea boards.
Sticky notes are simple, atomic pages for recording fragmented information or thoughts. Idea boards, on the other hand, are pages that aggregate sticky notes, organizing them and supplementing them with additional notes from a specific perspective.
A single sticky note can be added to multiple idea boards and managed as an embedded page.
This approach aims to organize the same information from various perspectives while minimizing redundancy. However, there arises an issue where the process becomes quite cumbersome if embedded pages on an idea board cannot be folded and unfolded as if they were directly written on the idea board itself.
Therefore, I consider the ability to fold and unfold embedded pages crucial. I would appreciate any guidance on implementing this feature in Logseq, even indirectly, perhaps through custom CSS or other methods.
In Logseq, information is organized into a hierarchy of blocks, and blocks sharing the same context are grouped together into a physical unit called a page (a file stored on disk).
Logseq provides the block embed feature, which allows many blocks to be grouped differently according to various contexts by using each blockâs UUID, thus enabling embedding of the same block across different pages.
I wish to treat each block shared across multiple pages as an independent physical entity. Currently, the only way to do this is by managing each shared block as a separate page.
The reasons for wanting to treat blocks shared across multiple pages as independent physical entities are:
To alleviate the burden of deciding physically which page each block should belong to, and
To make it easier to select only the needed blocks (on a page-by-page basis) to copy to another graph or to share with someone else.
Moreover, since block embeds are represented by UUIDs, which do not hint at their content, I prefer page embeds, which allow content to be inferred from the page title, over block embeds.
Embedding a page as a sub-block is inconvenient because it requires creating a block and repeating the page title every time.
I am currently also making use of the sidebar. Instead of page embeds, I organize page links and open the linked pages in the sidebar if needed. However, I still wish there was a way to display the content of shared blocks embedded within a page in a foldable manner.
I hope for a note-taking method that allows for frictionless recording and orderly reflection from various perspectives. To achieve this, I feel the need for something akin to a sticky note (or napkin) that lies between the block concept and the page concept of Logseq. This issue relates to personal preferences in note-taking methods and, in my view, is not a matter of right or wrong.
Perhaps my explanation of my needs was insufficient, making it hard to understand. In fact, I am more interested in finding a practical implementation method - preferably an easy one - rather than dwelling on the philosophy of note-taking.
Additionally, in Logseq, when we manage context using references or tags, the âPages tagged withâ area for a referenced tag or the âLinked Referencesâ for a referenced page list backlinks in an arbitrary order. From this contextual perspective, when organizing pages, the order is important, and there is a need to add additional information, which makes such an arbitrary order backlink list insufficient.
As mentioned earlier, a whiteboard could be a solution to this problem. However, for me, organizing information in an outliner format text seems to be much more time and effort efficient compared to using a whiteboard.
Sure, philosophical discussions go to category General. But avoiding a regrettable choice is a practical discussion. And for me to prepare a solution, I would like some guarantee that at least one person will use it (not just play with it and then dump it).
Would you be willing to use the normal typing for page-embedding (i.e. typing /embed or {{embed }}), then prepend embed with e.g. foldable-, to form in total something like {{foldable-embed [[pagename]]}} , which will use some custom.js to add a button for un/folding?
Thank you so much for the favor!! I believe that at least the users who voted and commented on the Feature Request mentioned above are willing to use it. It would be acceptable to maintain the existing procedure for embedding pages in Logseq as much as possible, if it involves adding a button for un/folding to the embedded page block. It doesnât matter whether itâs custom css, custom js, or both.
Thank you so much!!
Iâve confirmed that, by applying the custom CSS and custom JS you posted, clicking on the page icon of the embedded page does indeed make it un/fold as intended.
I will make good use of it.
I apologize for the confusion. After closing and restarting the app, it works well on Android just as it does on Windows.
Separately, there is an issue where the un/folding does not work when embedding page with an alias instead of the page name, but this is not a problem as long as we are careful not to embed using aliases
Embedding an aliasdoesnât work in general, as instead of the target page it embeds an empty page. Thus there is nothing to unfold, so it is not an issue of this implementation.
Ideas arenât arbitrary nor random. Sometimes they just arenât fully organized. Louis Pasteur accidentally injected chickens with a dated virus and they lived. He revealed the power of inoculation. Where do you note that? There is no permanence in complex environments. You need to stay liquid.
I would say that permanence can be found in just about the same frequency as non-permanence. Without enough permanence, Pasteur would have no chance. Granted that some of that permanence is so much fundamental, that it may get overlooked.
There are two types of complex environments:
Hardware, which is hard/solid.
The circuitry of the computers that facilitate this conversation, represents the most complex environments in the known non-biological universe. Its success primarily depends on its permanence.
Biological hardware is even more complex. Its success primarily depends on homeostasis. This is:
about maintaining relative permanence
many cells get replaced by others, but they are practically identical
the reason there was something for Pasteur to discover in first place
Software, which is soft/liquid.
It can be as complex as the hardware (e.g. virtual machines), but so far we have not reached that level (we use instead abstractions).
We have the quantity (e.g. LLMs), but it misses enough complexity (that shows off).
The exact boundary between hardware and software is not always easy to define in a multi-level system (e.g. code is software, but may function like hardware), however their roles are distinct enough. Like a piece of ice on an iceberg:
may contain electrons that move all the time
may itself be floating along with both:
the iceberg
the planet
yet it has crucially different properties than a drop of water in the surrounding sea
no matter they are made of the same type of molecule (same mass etc.)
the drop may let a ship pass, the ice may open a hole on it
The liquid sea is relatively chaotic, while the solid iceberg is ordered enough.
Knowledge management is like a city. A city:
is a complex environment
Like a living organism.
Though less complicated.
has software parts:
The various goods produced and consumed within it.
They are meant to move from production to distribution to consumption.
The inhabitants living there.
They move around most of the time.
has hardware parts:
some of them under construction
Things are expected to move around a lot.
some of them under maintenance
Some things are expected to move a little.
the presently useful ones, those settled to their designated permanent positions
If any of them moves, it is considered a damage.
Pasteur:
needed:
a stable environment to perform his experiments reliably
to consistently follow some rules
software in nature, hardware in role
used tools that were:
stable themselves
also produced in very stable environments
Likewise with notes:
Their content is software.
It is supposed to:
be produced and consumed
be edited, associated, enriched and generally improved in many ways
Their position is hardware.
It is supposed to:
be constructed and maintained
Think also of notes made-up of more than one block.
find a permanent page, within which to be used
It may still move a little within that page, but less and less.
Liquidity of content doesnât imply liquidity of position.
