How to show page title in table view mode by using advanced query
I want to fetch all pages that contains tag #inbox. I try query from https://docs.logseq.com/#/page/advanced%20queries
{:title "All blocks with tag inbox"
         [?p :block/name "inbox"]
         [?b :block/refs ?p]]
It works fine:
But in table view, i see only blocks:
How render only page titles in table view mode? I also see that the results in table / non-table view mode are sorted differently, how can I achieve the same sorting. Thanks in advance for your help.
It seems like you have your tags in an indented sub-block and not in the same block as your todo.
Instead of
“Add lsp server to emacs
- [[inbox]]”
try it in one line
“Add lsp server to emacs [[inbox]]” or “[[inbox]] Add lsp server to emacs”.
Then your table view should show work.
Look at the advanced queries and find something like
(sort-by (fn [h]
(get h :block/created-at)) result))
and decide what your sorting should be.
If i understand correctly you have a page that has a link to the page inbox and you want to grab that page and not the block which references inbox.
If so, here’s what you are looking for:
   :query [:find (pull ?p [*])
         [?i :block/name "inbox"]
         [?b :block/refs ?i]
         [?b :block/page ?p]
Same problem here.
Thanks @Siferiax . @Xardas solution outputs the blocks that link to “inbox”. Your solution outputs the pages linking to “inbox”. Is there a way to have best of both worlds? I.e. get all blocks, but with an additional table column “page title”, that shows, to which page each block belongs?
Yes, sort of :slight_smile:
   :query [:find ?page ?id ?block
         :keys page id block
         [?b :block/refs ?i]
         [?b :block/page ?p]
         [?b :block/uuid ?id]
         [?b :block/content ?block]
         [?p :block/original-name ?page]
   :view (fn [rows] [:table [:thead [:tr [:th "Page"] [:th "Block"] ] ]
   [:tbody (for [r rows] [:tr
     [:td [:a {:href (str "#/page/" (clojure.string/replace (get-in r [:page]) "/" "%2F"))}
 (get-in r [:page])] ]
     [:td [:a {:href (str "#/page/" (get-in r [:id]))} (get-in r [:block])] ]
Fantastic - thank you so much!
Out of curiosity, is there any way to get a bit more intuitive solution?
   :query [:find (pull ?bp [*]) (pull ?b [*])
         [?b :block/refs ?p]
         [?b :block/page ?bp]]
only returns page data. Probably because page and block types are different?
   :query [:find ?bp (pull ?b [*])
         [?b :block/refs ?p]
returns raw data, but overall value seems right:
29{:block/uuid #uuid "63dbd362-...",
 :block/properties {},
 :block/left {:db/id 30},
 :block/refs [{:db/id 26}],
 :block/format :markdown,
 :block/content "block with link to [[inbox]]",
 :db/id 31,
 :block/path-refs [{:db/id 26} {:db/id 29}],
 :block/parent {:db/id 30},
 :block/page {:block/name "pb", :block/original-name "PB", :db/id 29}}
33{:block/uuid #uuid "63dbd36d-...",
 :block/left {:db/id 34},
 :db/id 35,
 :block/path-refs [{:db/id 26} {:db/id 33}],
 :block/parent {:db/id 34},
 :block/page {:block/name "pc", :block/original-name "PC", :db/id 33}}
Yes, to turn that raw data into something more readable I made a custom table using :view.
The different return values get bound to keys (from the :find and :keys sections)
And then used in the :view to display them more nicely.
As you concluded correctly pages and blocks are different, most notable for this situation in their default result-transform and view used for :find (pull ?b [*]) (or ?p). Putting something different in :find will stop the default from working as intended and thus giving unexpected output.
At least that’s my interpretation.
@ste my goal is one page for each todo and first page block for status. You solution is nice, but I will have to duplicate the page title in the first block. @Siferiax you solution works perfect. Thanks guys.
There’s an alternative way thanks to Darwis on discord:
Makes the query a bit more concise and allows for the default table view usage.
I took their example from discord and applied it to the query I made for this thread.
The query basically adds another property to the block so it can be used in the table view.
:journal is what is used as a name for page. Please be aware that :page is reserved and doesn’t work.
         [?b :block/refs ?i]
  :result-transform (fn [res] (sort-by (fn [s] (get-in s [:block/properties :journal-day])) > (map (fn [m]
       (update m :block/properties
           (fn [u] (assoc u :journal-day (get-in m [:block/page :block/journal-day]) :journal (get-in m [:block/page :block/name]))
    ) res)))
PS. Also check out this feature request!
