Is it possible to add a folder argument when starting LogSeq to open that graph directly?
This is rather similar to this post I think: LogSeq opening a specific folder on Startup
I separate work and private graphs, and I often need to open that specific folder for quick note taking, and using the UI to switch folders tends to be a few steps that breaks my chain of thought if a meeting is a bit hectic. I’ve been making notes in the wrong graph so many times :sweat_smile:
Is there a way to open LogSeq with a folder argument on Windows, and have that folder open instantly? For example with a desktop shortcut like logseq.exe “D:\Work\Logseq Work\“ or something like that.*
It is a terribly minor thing, but if someone knows of a trick like that, that would be swell :slight_smile:
Also; I’m having a great time with LogSeq - thanks, @dev team!
I would like to have that as well, but found no way so far. There are more threads on that in the forum, but can’t find them right now.
What works for me right now is shift-click on the graph selection menu to open a new window with that graph. Well, worked, due to sync and performance problems I’m trying out alternatives to Logseq the last few days.
Thank you for the reply DonnerWolfBack! That is certainly the easiest way I’ve found so far :slight_smile:
