Nested number lists
When block has many levels, the content space becomes very small. To solve this problem, I implemented another hierarchical representation using CSS, which takes up almost no content space.
normal lists
nested number lists
To achieve this effect, simply copy the following code into custom.css
/* no indentation */
.block-children-container { margin-left: 0px !important; padding-left: 0px !important;}
.block-children { margin-left: 0px !important; padding-left: 0px !important;}
/* nested number lists */
.block-children { counter-reset: l-num; }
.block-children .bullet::after {
  counter-increment: l-num;
  content: counters(l-num, ".");
  position: absolute;
  top: -6px;
  font-size: 9px;
Good work, that will be so useful. But i want if i can replace the bullets with that nested numbers like cannibalox did it in this tuto.
Of course, this effect can be achieved.
Just use the CSS below, hope it help you
/* no bullet */
.bullet-container { display: none !important; }
.bullet { display: none !important; }
/* nested number list */
/* /level-1 */
.page-blocks-inner {  counter-reset: l-num-level-1; }
.ls-block[level="1"]>.block-main-container>.block-control-wrap>.bullet-link-wrap::after {
  	counter-increment: l-num-level-1;
 	content: counters(l-num-level-1, ".");
  	font-size: 9px;
  	display: inline-block;
  	width: max-content;
/* /children */
.block-children .bullet-link-wrap::after {
  	content: counters(l-num-level-1, ".") "." counters(l-num, ".");
  	font-size: 9px;
  	width: max-content;
One more last thing, how to have the last block have no numbers on it.
I’m glad you like it. There is a way that last block of every level has no numbers, I’m not sure if it’s the effect you want.
If yes, add the following CSS below the previous CSS
.page-blocks-inner .ls-block:not(:has(.ls-block)):last-child .bullet-link-wrap::after {visibility: hidden;}
Thank you so much for this
well, you’re welcome.
amazing feature! thanks for sharing it!
Is there a possibility to apply this style selectively on a block (and all its child blocks)?
I’m glad you like this feature.
Sure for your question, use this CSS. It takes effect when there is an [[nnl]] or #nnl tag in the block.
[data-refs-self*="nnl"] .block-children-container { margin-left: 0px !important; padding-left: 0px !important;}
[data-refs-self*="nnl"] .block-children { margin-left: 0px !important; padding-left: 0px !important;}
/* no bullet space */
[data-refs-self*="nnl"] .block-children-left-border { display: none !important; }
[data-refs-self*="nnl"] .bullet-container {
  position:absolute !important;
  left:-9px;
  top:9px;
/* /children */
[data-refs-self*="nnl"] .block-children { counter-reset: l-num; }
[data-refs-self*="nnl"] .block-children .bullet-link-wrap::after {
  font-size: 9px;
  width: max-content;
Similarly, the following CSS can be used to implement a dashboard.
div[data-refs-self*="dashboard"]>.block-children-container.flex {
    width: 100%;
div[data-refs-self*="dashboard"]>.block-children-container.flex>.block-children.w-full {
    display: inline-flex;
    position: relative;
    overflow-x: auto !important;
    overflow-y: hidden;
    margin: 0 10px;
div[data-refs-self*="dashboard"]>.block-children-container.flex>.block-children.w-full>div.ls-block {
    padding: 0;
    width: inherit;
    min-width: 100px;
    margin-right: 10px;
