The goal is to have a progress bar that fills based on a variable.
I’m having trouble using a page property inside a hiccup command.
I have set a page property like so:
myprop:: 300
And here is an example progress bar:
[:progress {:max 600 :value 50 }]
How would I go about replacing the value of ‘50’ in the progress bar above with ‘myprop’ page property?
My use case is a bit different from the suggestions in that link, but it was a good reference. I’m trying to track my progress in learning Kanji. Here’s what I’ve come up.
On a journal page set a property with the number of learned kanji so far. learned_kanji:: 416
Make Queries to show the progress towards JLPT Levels.
Example for JLPT N2:
:where [?b :block/properties ?p]
[(get ?p :learned-kanji)]]
:view (fn [result]
(let [total 1000 ;; Set the total value for the progress bar
limited-result (take 1 result)] ;; Limit to a single result
[:div
(for [r limited-result]
(let [progress (get-in r [:block/properties :learned-kanji])
progress-ratio (/ progress total)
progress-percent (* progress-ratio 100)
;; progress-rounded (/ (Math/round (* progress-percent 10)) 10.0) ;; This breaks query view
[:div
[:h4 {:style {:display "inline-block" :margin-right "10px"}} "Kanji N2"]
;; [:span (str "Progress: " progress-percent "%")] ;; This works but displays too many decimals
;; [:span (format "%.1f" (float progress-percent)) ] ;; Format breaks query view
[:progress {:value progress :max total :style {:width "200px" :margin-right "4px"}}]
[:small (str progress "/" total)]]))]))
End Result:
Nice. Concerning rounding, could achieve it through multiplication, int and division.
Thanks for the rounding tip!
:query [
:find (pull ?b [*])
(take 1 (sort-by (fn [d] (get d :block/created-at)) > result))) ;; Take only the Latest
:view (fn [result]
(let [total 620 ;; Set the total value for the progress bar
r (first result) ;; Get the first result directly
progress-rounded (/ (int (+ (* progress-percent 10) 0.5)) 10.0)
[:div
[:h4 {:style {:display "inline-block" :margin-right "10px"}} "Kanji N3"]
[:span (str "Progress: " progress-rounded "%")]
I’m having trouble now making a global variable for the property :learned-kanji
I would like it before the :query so I can use it in both :query and :view.
Is this possible in logseq?
I have tried some variations of the following with no success:
let [property-name "learned-kanji"]
:query [
:find (pull ?b [*])
[(get ?p (keyword property-name))]
