Provide option to disable "lazy-load"
Currently there is no such option for we user to disable lazy-load.
I have to admit lazy-load is an amazing feature that improve the software performance but currently it is sometimes annoy me…
For example when i try to edit the last two rows, it will fold automatically… I unfold it and try to add it again. Same thing happened. I know it’s a bug but I wonder is it possible to give us an option to disable that feature before the bug got fixed?
What’s lazy-load? Rows in a table?
I think I’m missing something here
If you have a long page with lots of bullets it can become slow to load. The Devs introducted lazy load which leads the page section by section which results in much faster performance.
The issue is that when you are working on the page. Lazy load can get in the way but having to render before you can do anything and if you undo or scroll to another section to then go back, you need to wait for it to render
Improve long page editing performance by tiensonqin · Pull Request #3855 · logseq/logseq (github.com)
this is a feature to improve page performance. it will only render at most N bullets. then when user scroll to the bottom of the page, it will render the next N.
Thx. will try to wait for longer time :joy:
If there are potential bugs i will record a video and post it here for reviewing.
Ah yes, I’ve seen that.
Interesting. I actually think that this lazy-loading introduces more problems than it solves. It may be faster for the initial loading. But when I’m trying to get to lower parts of the page, it takes forever to scroll and wait and scroll and wait. And then if I go to another section or another note and come back, the long note isn’t cached and I have to start all over again.
I agree, lazy loading is not great. I think it needs more polish before it’s useful.
I need this. I helped a friend switch to logseq but he needed large documents. Using table of contents addons would win him over but the lazy loading makes clicking on the links generated broken (clicking does nothing).
I you want to know more: page link don't work until loaded because of lazy loading · Issue #31 · sethyuan/logseq-plugin-tocgen · GitHub
Huh, I don’t know if there have done some work with lazy-loading but the performance is dramatically better for me with Version 0.8.5. And there’s even a “scroll to bottom” button that I didn’t notice before.
bugreport.mp4
Related problems caused by lazy-load is usually annoying :joy:
actually, no, just as slow as before.
Looking at the issues on GitHub tagged with lazy-loading, it’s clear that these issues are common. I’d like to +1 the ability to disable it. Logseq is a huge boon to my productivity, but blocks that autoclose even when typing is nearly a blocking issue.
Lazy loading has been a recurring problem for me since it was introduced, and significantly decreases the usability of logseq for my use case, where I commonly have pages with lots of blocks.
Lazy loading often simply doesn’t work for me. My current guess is this bug might be triggered by a dynamic query being earlier on the page (on longer pages I like to have a query at the top listing the remaining tasks on the page). As a workaround I collapse an earlier block and then more blocks do get lazy loaded, but it’s very annoying.
I’ve also run into the problem others described adding/editing blocks at the end of a long page.
An option to disable lazy loading altogether would be simplest from an end user perspective, but I acknowledge that implementing such an option might be tricky.
As a compromise, could we at least make configurable the cutoff limit for how many blocks are loaded before lazy loading kicks in? Then those of us who want to avoid lazy loading could increase that limit as high as we want and live with the slower page performance to avoid the problems lazy loading causes.
I’ve submitted logseq issue 9076 for this.
Anyone found a workaorund for this? or a plugin exposing a button that would load the entire page?
The current behavior breaks ToC-based page navigation which is a must in very long pages full of images and blocks
I love Logseq so much and lazy-load is the only thing that annoys me. I am already a patron but I would contribute 200 USD for this feature alone to be added.
Lazy-load is great for something like the Journals page where we know that the user is generally interested in the information at the top of the page, and the page can be excessively long. But on any other page we should expect the user to want to access information far below the top of the document, thus it makes little sense to prioritize loading the top of these pages over any other portion.
I would recommend:
  • Lazy-load should be default off for all pages except the Journals page.
  • Add a lazy-load include list to preferences, and include Journals by default.
  • Allow users to add additional pages to the include list at their discretion, or check a box to force all pages to lazy-load.
This also effects if you try to search for something on a page, if not all blocks is loaded they search result will just return nothing, with no indication that the page you are currently on is not entirely loaded in.
This has made logseq actually unusable for me as a student. I didn’t realize until mid-semester that I’d have to go to class and scroll all the way down to my last bit of notes since i write top down. when i briefly look at connected notes and come back to class notes, I have to scroll all the way again, making me forget what I was going to write in the first place! This made me move over to obsidian and then to doom emacs, which did not have the same problem.
