Description of the issue
- Currently it is hard to select multiple specific texblocks
- via keyboard
- or even with mouse
- Copy and Pasting thus becomes a little tricky
- There is the system native “selection”
- only works for single lines
- there is the logseq specific selection
- not precises with mouse, does work so/so with keyboard
Why is this an issue?
- It makes copy&paste harder
- The system behaviors are different depending on the type of selection
- The system native selection copys what you see/select
- The logseq selection copies the underlying markdown
- Tools that do not support markdown will have you delete a lot of #####
- When using notes from logseq in other tools (Word, Powerpoint, Keynote, …) you often want to transfer snippets of information
Suggested behavior
- Use one way of selection … ideally the system native one
- Use one way of behavior WYSIWYG or MD copy&past
