My question is about the link between TestNamespace and NoteA
My scenario :
I will use namespace as system separation like Habit/GTD/PKM/Personal/Work …
I current situation, my graph shows a lot of big dots which is namespace.
Inside [[TestNamespace - TestTag]] write a property namespace:: TestNamespace
Then the graph is totally clean. But this is not a namespace should looks like. For example if I want to change namespace name, then I need to change all of them one by one.
So my question is :
Is this reasonable to have that additional link?
If we want to see all nodes under a specific namespace, then we can use a query.
Or if Page graph support N level graph, then everything works fine.
Current method just create a lot of useless links in the graph and make the graph totally a mess.
Most scary thing:
If I use [[NS1/NS2/NS3/TestTag]], then logseq will create link like
What you have experienced is expected. A Page is a node in the graph. Therefore NoteA will show.
By adding the namespace in the page, you implied that you want a relationship between the page and the namespace [[TestNamespace/TestTag]]. Therefore the graph will link them.
Every time there is / in a backlink, logseq will split it has namespace hierarchy. I hope this helps to confirm that it is working as intended.
NoteA is a page, which contains the namespace TestNamespace. The relationship is “contains” therefore the connection will be drawn between them. I hope that I am not confusing you
I understand what you say, let’s define this question more clearly.
If NodeA write a Line [[TagA]], then NodeA contain TagA, and a link should be created.
If NodeA write a Line [[TestNamespace/TagA]], then
NodeA contain TestNamespace/TagA, then a link should be created between NodeA and TestNamespace/TagA. This is a strong relation
And the question is, does NodeA contains [[TestNamespace]]? This is a weak relation
Current logseq do not split strong and weak relation, and treate this question as TRUE. And this is why you say it’s expected.
My point is this should be false, or at least give a option to hide weak relation in the graph. Or Graph view will be totally a mess if one use namespace as classification method.
I think @Raymon Is right. The namespace graph should look like a tree, not a circle. The note should not have a direct relation to the root node but belongs to the TestNamespace through TestTag.
