Templates injecting dynamic dates (and placeholders/arguments)
in my template, I want to use something akin to the thing you get from the /today or /tomorrow commands
I want to create a template with a link to yesterday/tomorrow in one of the bullets, something like [[{yesterday}]] (that will be evaluated every time the template is used)
EDIT: now that I’ve created some of my own templates - I really think templates need to be parameterized and should also be able to use hooks, like arg0 or arg1 so I can “pre-embed” a template in another template, so when they are finally embedded on a page - the sub-templates with the parameters run
Hello, I wonder how to insert current time in templates, how to do it in Logseq? Thanks!
I found out by accident you can use <%time%> inside a template. Not sure what else is possible though. I ran into your question looking for exactly that :wink:
@TomBen found something here: https://logseq.github.io/#/page/Dynamic%20Variables maybe this helps :slight_smile:
Great, Thanks so much!
It’s been moved to Dynamic Variables
I believe this will not work reliably (for properties added to the page that you do not edit, at least) because Dynamic variables don’t get properly processed when used in templates #9892
It looks like YU000jp’s logseq plugin default-template to Automatically apply a page template will work (written in response to Extend default template functionality - Feedback / Feature Requests - Logseq.
It’s been all most 4 years since this was written, and and as a newbie with only days under my belt, this worked perfect! and now I’m off to chase the link below! Thx!
