When you embed a block or paste its reference inside/under another block, what you get is two things:
a first block that has a second block inside/under it and
the second block that just has information saying that it is inside/under the first block (linked reference)
The right way is to have the linking of blocks as a separate thing.
It’s doing things the first way that hurts our brains when we’re note-taking. Doing things the first way creates a hierarchy or one-wayness in our minds where there isn’t supposed to be:
By having the linking of blocks as a separate thing we get what’s actually being represented in the graph view (this is how we think anyway):
Having the linking of blocks as a separate thing also frees each block to be its own thing. There won’t be a “real” hierarchy of blocks. The outline view will simply be used to show hierarchy like, “by the way this block can be viewed as being lower in an arbitrary hierarchy with this other block.”
Also, hyperlinking won’t go away. It just won’t be used to show linked references since that’s what linking is for. It simply brings you from one block to another.
Interesting idea. Not sure if I followed precisely. The ideal for me would be to make all of this configurable according to user preference. For example, I would like to have the option to have whiteboards show hierarchy relations as link-lines, and to make it so that creating a link between items in a whiteboard creates a hierarchy relationship (creates an embed of the one block under the other). Hierarchical relationships are a kind of metadata that can mean different things to different people.
And that is redundant. If you’re just gonna manually put them inside/under each other then there’s no use for linked references.
Also it will be tedious if one block is linked to multiple blocks. You’re gonna have to embed or paste the reference of all of the blocks inside/under that one block and then you’re gonna have to embed or paste the reference of that one block inside/under all of those blocks. Plus, it’s gonna clutter up the hierarchy of blocks in the outline view.
I don’t necessarily disagree with the feature request in the title of this topic (it depends on its implementation). But I do disagree with the thinking approach:
References are rarely mutual. Most often:
only one thing references another thing
the other thing merely back-references the first thing
Here are the typical references in your example:
video1.md:
This is a video about [[philosophy]].
journal:
I watched [[video1]] on this date.
That doesn’t create a hierarchy, but it does create a chain of specific direction, like in your image:
So how I understand what you’re saying is that you agree that the linking must be a separate thing but there should be an option with regards to the linking? Kinda like how the arrows in the whiteboard, you can choose where the arrows point, either two ways in one direction or two directions. Yeah I agree with that.
Hmm, I see where we’re not meeting. You’re referring to references which, yes, I agree are one-way.
Thanks to what you’ve said, it’s now clear to me what I’m getting at with this post.
What Logseq needs is a new “linking” feature. Because the reason we’re using something like Logseq is to see the links/connections/relations between objects, thoughts, etc.
Links, connections, and relations are fundamentally two-way/bidirectional. When an object is “related” to a second object, it means that the second object is also, equally, “related” to that first object. Whether that relation is hierarchical or not, they equally have a link/connection/relation to each other. These are what we actually want to see when we’re using apps like Logseq.
The problem lies in that we can only see those links/connections/relations through references which are one-way, as you said.
References should just be a means to travel from one block to the next, not as a way (in this case, the only way) to say that one block is “linked/connected/related” (linked reference) to another block.
edit:
Yes, I agree. Btw I realized that this is what I was getting at in my first post in this forum right here: Can Logseq do relations like in Notion?. Now I was able to articulate it better here thanks to you
