There is some sort of problem when unselecting/disabling the transparent background feature when trying to export a block as png. Please advise.
Copilot advice attached:
To export a block as a PNG without a transparent background in Logseq, you might need to use a workaround since there seems to be no direct feature to change the background of exported PNGs. Here’s a method you can try:
- Export the block as a PNG with a transparent background as you normally would.
- Open the PNG in an image editing software that allows you to add layers, such as Photoshop or GIMP.
- Create a new layer beneath the exported PNG layer and fill it with the background color of your choice.
- Merge the layers if necessary, so that the background becomes part of the image.
- Save the new image as a PNG.
This method should give you a PNG file of the block with a solid background. If you’re looking for a more automated solution, you might want to check if there are any plugins or updates for Logseq that address this issue123.
