This request is to solve the same problem as A property which appears as a tooltip but I think having a class of “visible in editing mode” properties would be a better solution because this way you could have many types of such properties and put as many as you like in one block, compared to a “prompt” or “tooltip” that usually means only one per block.
This is actually kind of supported by logseq according to feat: Add version 2 of tables by bendyorke · Pull Request #8532 · logseq/logseq · GitHub
But it is only available for specified built-in properties, so I’m requesting an exposed setting to allow users to define custom properties to behave the same as those “editable-built-in-properties” similar to the solution for Control which block properties are hidden in view mode .
