Hello! I would like to see more options for text formatting so that I can quickly add bold strike through underline and italics to my text — the same way we can quickly add highlights and headinsg to text using the context menu.
When you say using the context menu, do you mean the right-click on the bullet?
Isn’t that being applied to the entire block, though?
For bold, and strike-through, I still find the shortcuts quite convenient. Just CTRL + B for bold, and CTRL + tilde twice for the strike-through.
I ended up finding what I was looking for: it was logseq-plugin-wrap
As much as the shortcuts are handy, they might be frustrating for beginners to remember. Also, AFAIK, there’s no shortcut for underline or other formatting which requires html tags.
Here’s how I set it up:
Here’s how I set up the settings file logseq-wrap.json
"disabled": false,
"toolbar": true,
"wrap-bold": {
"label": "Wrap bold",
"binding": "",
"template": "**$^**",
"icon": "<svg t=\"1644033307902\" viewBox=\"0 0 1024 1024\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\" p-id=\"1224\" width=\"200\" height=\"200\"><path d=\"M697.8 481.4c33.6-35 54.2-82.3 54.2-134.3v-10.2C752 229.3 663.9 142 555.3 142H259.4c-15.1 0-27.4 12.3-27.4 27.4v679.1c0 16.3 13.2 29.5 29.5 29.5h318.7c117 0 211.8-94.2 211.8-210.5v-11c0-73-37.4-137.3-94.2-175.1zM328 238h224.7c57.1 0 103.3 44.4 103.3 99.3v9.5c0 54.8-46.3 99.3-103.3 99.3H328V238z m366.6 429.4c0 62.9-51.7 113.9-115.5 113.9H328V542.7h251.1c63.8 0 115.5 51 115.5 113.9v10.8z\" p-id=\"1225\" fill=\"#eee\"></path></svg>"
"wrap-italic": {
"label": "Wrap italic",
"binding": "mod+shift+i",
"template": "*$^*",
"icon": "<svg t=\"1644033462513\" viewBox=\"0 0 1024 1024\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\" p-id=\"2021\" width=\"200\" height=\"200\"><path d=\"M382.72 810.666667L542.72 213.333333H426.666667a42.666667 42.666667 0 1 1 0-85.333333h341.333333a42.666667 42.666667 0 0 1 0 85.333333h-136.874667L471.04 810.666667H597.333333a42.666667 42.666667 0 0 1 0 85.333333H256a42.666667 42.666667 0 0 1 0-85.333333h126.72z\" fill=\"#eee\" p-id=\"2022\"></path></svg>"
"wrap-underline": {
"label": "Wrap underline",
"binding": "",
"template": "<u>$^</u>",
"icon": "<svg t=\"1669000720199\" class=\"icon\" viewBox=\"0 0 1024 1024\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\" p-id=\"3263\" width=\"200\" height=\"200\"><path d=\"M512 811.296a312 312 0 0 0 312-312V89.6h-112v409.696a200 200 0 1 1-400 0V89.6h-112v409.696a312 312 0 0 0 312 312zM864 885.792H160a32 32 0 0 0 0 64h704a32 32 0 0 0 0-64z\" p-id=\"3264\" fill=\"#eeeeee\"></path></svg>"
"wrap-strike-through": {
"label": "Wrap strike through",
"binding": "",
"template": "~~$^~~",
"icon": "<svg t=\"1647222242775\" viewBox=\"0 0 1024 1024\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\" p-id=\"1518\" width=\"200\" height=\"200\"><path d=\"M1014.869333 468.650667H578.161778c-11.406222-2.275556-23.409778-4.579556-36.124445-6.855111a2110.094222 2110.094222 0 0 1-35.185777-6.627556c-58.624-11.434667-93.923556-22.869333-122.026667-39.111111-40.135111-23.409778-59.676444-55.182222-59.676445-97.251556 0-42.268444 17.351111-77.368889 50.289778-101.717333 32.426667-23.978667 78.620444-36.693333 133.489778-36.693333 62.606222 0 110.933333 16.497778 143.758222 48.924444a144.839111 144.839111 0 0 1 36.352 60.131556c1.479111 4.664889 3.185778 11.406222 4.892445 20.337777 1.052444 5.489778 5.973333 9.386667 11.320889 9.386667h83.2a11.576889 11.576889 0 0 0 11.548444-11.576889v-1.137778a268.629333 268.629333 0 0 0-2.275556-18.289777C789.333333 238.478222 765.724444 194.844444 729.486222 162.133333c-50.744889-46.307556-125.383111-70.627556-215.665778-70.627555-82.631111 0-157.013333 20.679111-209.464888 58.168889-29.269333 21.048889-51.911111 47.075556-66.986667 77.368889-15.416889 30.976-23.210667 66.730667-23.210667 106.154666 0 33.735111 6.542222 62.293333 19.797334 87.438222 9.472 17.92 22.385778 33.706667 38.968888 48.014223H9.102222a9.159111 9.159111 0 0 0-9.130666 9.130666v68.551111c0 5.034667 4.124444 9.159111 9.130666 9.159112h495.104l6.741334 1.365333c35.299556 7.111111 56.576 11.889778 76.117333 17.379555 26.282667 7.424 46.392889 15.217778 63.089778 24.576 40.903111 23.096889 60.899556 56.234667 60.899555 101.717334 0 40.334222-17.720889 76.344889-49.834666 101.489778-34.844444 27.306667-86.385778 41.585778-149.134223 41.585777-49.948444 0-92.216889-9.699556-125.952-28.558222-33.251556-18.631111-56.092444-45.511111-68.209777-79.445333a122.965333 122.965333 0 0 1-3.100445-10.268445 11.690667 11.690667 0 0 0-11.093333-8.590222H212.707556a11.576889 11.576889 0 0 0-11.548445 11.548445v1.137777c0.227556 2.645333 0.483556 4.835556 0.711111 6.542223 7.395556 55.751111 34.616889 101.461333 80.782222 135.765333 53.845333 39.765333 129.592889 60.785778 219.192889 60.785778 96.227556 0 176.924444-22.613333 233.386667-65.479111a215.893333 215.893333 0 0 0 65.251556-78.876445c14.848-30.947556 22.528-66.161778 22.528-104.561778 0-36.323556-6.627556-66.730667-20.366223-93.013333a157.184 157.184 0 0 0-24.888889-35.214222h237.141334a9.159111 9.159111 0 0 0 9.130666-9.130667v-68.579555a9.159111 9.159111 0 0 0-9.130666-9.016889z\" p-id=\"1519\" fill=\"#eee\"></path></svg>"
"wrap-inline-code": {
"label": "Wrap inline code",
"binding": "",
"template": "`$^`",
"icon": "<svg xmlns=\"http:\/\/www.w3.org\/2000\/svg\" height=\"48\" width=\"48\" fill=\"#fff\"><path d=\"m16 35.9-12-12 12.1-12.1 2.15 2.15L8.3 23.9l9.85 9.85Zm15.9.1-2.15-2.15 9.95-9.95-9.85-9.85L32 11.9l12 12Z\"\/><\/svg>"
"group-hl": {
"wrap-yellow-hl": {
"label": "Wrap with yellow highlight",
"binding": "",
"template": "==$^==",
"icon": "<svg t=\"1643262039637\" viewBox=\"0 0 1024 1024\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\" p-id=\"6950\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" width=\"200\" height=\"200\"><defs><style type=\"text/css\"></style></defs><path d=\"M114.727313 1024l0.305421-0.427589h-0.977347l0.671926 0.427589zM632.721199 809.365446c-156.680934 0-272.466006 41.644143-341.659116 75.927642L290.878831 972.108985C340.402833 942.605324 458.249497 885.720677 632.73647 885.720677H962.804862v-76.355231H632.73647z m-109.432317-72.018253l252.048617-528.378197a38.177615 38.177615 0 0 0-13.621773-48.790993L551.295981 24.464216a38.192886 38.192886 0 0 0-50.089031 7.696607L130.349594 483.908911a38.208157 38.208157 0 0 0-7.024682 35.886958c31.763776 100.315502 36.436716 182.626441 34.695817 234.777064L94.477906 870.449631h132.094549l32.221908-42.606219c49.78361-25.624815 134.15614-60.931474 233.326314-69.177839a38.147073 38.147073 0 0 0 31.152934-21.31838z m-59.343285-52.54767c-71.66702 8.505973-134.950235 28.572127-184.489509 49.157497l-45.339736-29.244053c-2.290657-50.883126-10.613377-114.716099-31.901215-187.849139l336.161539-409.874879 153.474014 98.986922-193.728492 408.653195-176.838714-112.746134-47.935814 60.015211 191.117142 121.847678-0.519215 1.053702z\" p-id=\"6951\" fill=\"#ffe79a\"></path></svg>"
"wrap-green-hl": {
"label": "Wrap with green highlight",
"binding": "",
"template": "[[#green]]==$^==",
"icon": "<svg t=\"1643262039637\" viewBox=\"0 0 1024 1024\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\" p-id=\"6950\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" width=\"200\" height=\"200\"><defs><style type=\"text/css\"></style></defs><path d=\"M114.727313 1024l0.305421-0.427589h-0.977347l0.671926 0.427589zM632.721199 809.365446c-156.680934 0-272.466006 41.644143-341.659116 75.927642L290.878831 972.108985C340.402833 942.605324 458.249497 885.720677 632.73647 885.720677H962.804862v-76.355231H632.73647z m-109.432317-72.018253l252.048617-528.378197a38.177615 38.177615 0 0 0-13.621773-48.790993L551.295981 24.464216a38.192886 38.192886 0 0 0-50.089031 7.696607L130.349594 483.908911a38.208157 38.208157 0 0 0-7.024682 35.886958c31.763776 100.315502 36.436716 182.626441 34.695817 234.777064L94.477906 870.449631h132.094549l32.221908-42.606219c49.78361-25.624815 134.15614-60.931474 233.326314-69.177839a38.147073 38.147073 0 0 0 31.152934-21.31838z m-59.343285-52.54767c-71.66702 8.505973-134.950235 28.572127-184.489509 49.157497l-45.339736-29.244053c-2.290657-50.883126-10.613377-114.716099-31.901215-187.849139l336.161539-409.874879 153.474014 98.986922-193.728492 408.653195-176.838714-112.746134-47.935814 60.015211 191.117142 121.847678-0.519215 1.053702z\" p-id=\"6951\" fill=\"#ccffc1\"></path></svg>"
"wrap-red-hl": {
"label": "Wrap with red highlight",
"binding": "",
"template": "[[#red]]==$^==",
"icon": "<svg t=\"1643262039637\" viewBox=\"0 0 1024 1024\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\" p-id=\"6950\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" width=\"200\" height=\"200\"><defs><style type=\"text/css\"></style></defs><path d=\"M114.727313 1024l0.305421-0.427589h-0.977347l0.671926 0.427589zM632.721199 809.365446c-156.680934 0-272.466006 41.644143-341.659116 75.927642L290.878831 972.108985C340.402833 942.605324 458.249497 885.720677 632.73647 885.720677H962.804862v-76.355231H632.73647z m-109.432317-72.018253l252.048617-528.378197a38.177615 38.177615 0 0 0-13.621773-48.790993L551.295981 24.464216a38.192886 38.192886 0 0 0-50.089031 7.696607L130.349594 483.908911a38.208157 38.208157 0 0 0-7.024682 35.886958c31.763776 100.315502 36.436716 182.626441 34.695817 234.777064L94.477906 870.449631h132.094549l32.221908-42.606219c49.78361-25.624815 134.15614-60.931474 233.326314-69.177839a38.147073 38.147073 0 0 0 31.152934-21.31838z m-59.343285-52.54767c-71.66702 8.505973-134.950235 28.572127-184.489509 49.157497l-45.339736-29.244053c-2.290657-50.883126-10.613377-114.716099-31.901215-187.849139l336.161539-409.874879 153.474014 98.986922-193.728492 408.653195-176.838714-112.746134-47.935814 60.015211 191.117142 121.847678-0.519215 1.053702z\" p-id=\"6951\" fill=\"#ffc7c7\"></path></svg>"
"wrap-blue-hl": {
"label": "Wrap with blue highlight",
"binding": "",
"template": "[[#blue]]==$^==",
"icon": "<svg t=\"1643262039637\" viewBox=\"0 0 1024 1024\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\" p-id=\"6950\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" width=\"200\" height=\"200\"><defs><style type=\"text/css\"></style></defs><path d=\"M114.727313 1024l0.305421-0.427589h-0.977347l0.671926 0.427589zM632.721199 809.365446c-156.680934 0-272.466006 41.644143-341.659116 75.927642L290.878831 972.108985C340.402833 942.605324 458.249497 885.720677 632.73647 885.720677H962.804862v-76.355231H632.73647z m-109.432317-72.018253l252.048617-528.378197a38.177615 38.177615 0 0 0-13.621773-48.790993L551.295981 24.464216a38.192886 38.192886 0 0 0-50.089031 7.696607L130.349594 483.908911a38.208157 38.208157 0 0 0-7.024682 35.886958c31.763776 100.315502 36.436716 182.626441 34.695817 234.777064L94.477906 870.449631h132.094549l32.221908-42.606219c49.78361-25.624815 134.15614-60.931474 233.326314-69.177839a38.147073 38.147073 0 0 0 31.152934-21.31838z m-59.343285-52.54767c-71.66702 8.505973-134.950235 28.572127-184.489509 49.157497l-45.339736-29.244053c-2.290657-50.883126-10.613377-114.716099-31.901215-187.849139l336.161539-409.874879 153.474014 98.986922-193.728492 408.653195-176.838714-112.746134-47.935814 60.015211 191.117142 121.847678-0.519215 1.053702z\" p-id=\"6951\" fill=\"#abdfff\"></path></svg>"
"group-text": {
"wrap-red-text": {
"label": "Wrap with red text",
"binding": "",
"template": "[[$red]]==$^==",
"icon": "<svg t=\"1643270432116\" class=\"icon\" viewBox=\"0 0 1024 1024\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\" p-id=\"12761\" width=\"200\" height=\"200\"><path d=\"M256 768h512a85.333333 85.333333 0 0 1 85.333333 85.333333v42.666667a85.333333 85.333333 0 0 1-85.333333 85.333333H256a85.333333 85.333333 0 0 1-85.333333-85.333333v-42.666667a85.333333 85.333333 0 0 1 85.333333-85.333333z m0 85.333333v42.666667h512v-42.666667H256z m401.578667-341.333333H366.421333L298.666667 682.666667H213.333333l256.128-640H554.666667l256 640h-85.333334l-67.754666-170.666667z m-33.877334-85.333333L512 145.365333 400.298667 426.666667h223.402666z\" p-id=\"12762\" fill=\"#f00\"></path></svg>"
"wrap-blue-text": {
"label": "Wrap with blue text",
"binding": "",
"template": "[[$blue]]==$^==",
"icon": "<svg t=\"1643270432116\" class=\"icon\" viewBox=\"0 0 1024 1024\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\" p-id=\"12761\" width=\"200\" height=\"200\"><path d=\"M256 768h512a85.333333 85.333333 0 0 1 85.333333 85.333333v42.666667a85.333333 85.333333 0 0 1-85.333333 85.333333H256a85.333333 85.333333 0 0 1-85.333333-85.333333v-42.666667a85.333333 85.333333 0 0 1 85.333333-85.333333z m0 85.333333v42.666667h512v-42.666667H256z m401.578667-341.333333H366.421333L298.666667 682.666667H213.333333l256.128-640H554.666667l256 640h-85.333334l-67.754666-170.666667z m-33.877334-85.333333L512 145.365333 400.298667 426.666667h223.402666z\" p-id=\"12762\" fill=\"#00beff\"></path></svg>"
"wrap-green-text": {
"label": "Wrap with green text",
"binding": "",
"template": "[[$green]]==$^==",
"icon": "<svg t=\"1643270432116\" class=\"icon\" viewBox=\"0 0 1024 1024\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\" p-id=\"12761\" width=\"200\" height=\"200\"><path d=\"M256 768h512a85.333333 85.333333 0 0 1 85.333333 85.333333v42.666667a85.333333 85.333333 0 0 1-85.333333 85.333333H256a85.333333 85.333333 0 0 1-85.333333-85.333333v-42.666667a85.333333 85.333333 0 0 1 85.333333-85.333333z m0 85.333333v42.666667h512v-42.666667H256z m401.578667-341.333333H366.421333L298.666667 682.666667H213.333333l256.128-640H554.666667l256 640h-85.333334l-67.754666-170.666667z m-33.877334-85.333333L512 145.365333 400.298667 426.666667h223.402666z\" p-id=\"12762\" fill=\"#0f0\"></path></svg>"
"wrap-add-todo": {
"label": "Add TODO",
"binding": "",
"template": "TODO $^",
"icon": "<svg xmlns=\"http://www.w3.org/2000/svg\" height=\"48\" width=\"48\" fill=\"#fff\"><path d=\"M9 42q-1.25 0-2.125-.875T6 39V9q0-1.25.875-2.125T9 6h30q.7 0 1.275.3t.925.7L39 9.2V9H9v30h30V21.85l3-3V39q0 1.25-.875 2.125T39 42Zm14.05-8.4-11.1-11.1 2.1-2.1 9 9 19.1-19.1 2.1 2.1Z\"\/><\/svg>"
"repl-clear": {
"label": "Remove formatting",
"binding": "mod+shift+x",
"regex": "\\[\\[(?:#|\\$)(?:red|green|blue)\\]\\]|==([^=]*)==|~~([^~]*)~~|\\^\\^([^\\^]*)\\^\\^|\\*\\*([^\\*]*)\\*\\*|\\*([^\\*]*)\\*|_([^_]*)_|\\$([^\\$]*)\\$|`([^`]*)`|<u>([^<u>]*)</u>",
"replacement": "$1$2$3$4$5$6$7$8$9",
"icon": "<svg t=\"1643381967522\" viewBox=\"0 0 1024 1024\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\" p-id=\"1377\" width=\"200\" height=\"200\"><path d=\"M824.4 438.8c0-37.6-30-67.6-67.6-67.6l-135.2 0L621.6 104.8c0-37.6-30-67.6-67.6-67.6-37.6 0-67.6 30-67.6 67.6l0 266.4L358.8 371.2c-37.6 0-67.6 30-67.6 67.6l0 67.6L828 506.4l0-67.6L824.4 438.8 824.4 438.8zM824.4 574c-11.2 0-536.8 0-536.8 0S250 972 88.4 972L280 972c75.2 0 108.8-217.6 108.8-217.6s33.6 195.2 3.6 217.6l105.2 0c-3.6 0 0 0 11.2 0 52.4-7.6 60-247.6 60-247.6s52.4 244 45.2 244c-26.4 0-78.8 0-105.2 0l0 0 154 0c-7.6 0 0 0 11.2 0 48.8-11.2 52.4-187.6 52.4-187.6s22.4 187.6 15.2 187.6c-18.8 0-48.8 0-67.6 0l-3.6 0 90 0C895.6 972 903.2 784.4 824.4 574L824.4 574z\" p-id=\"1378\" fill=\"#eeeeee\"></path></svg>"
That said, it would be nice to have more text formatting options in the mobile app’s bottom toolbar.
Appreciate it! But I was wondering is there a way to change the built-in text color styles? The original green color is a bit too bright for me lol.
There should be, by modifying the CSS classes that the plugin author created. I’d consult with the author of the plugin:
Adding underline support with CTRL/CMD+u in
That’s great! That said, the original thread was about adding a pop-up text formatter when text is selected, on both desktop and mobile (similar to MS Word)
Is there any way to navigate the custom/built in formatting shortcuts using keyboard only? All the examples I see seem to require using the mouse pointer to select the formatting option
