Multi window mod+n doesn't open window?
Hello, I need to run multiple pages in multiple windows and the forum thread says Command+N, however no multi window opens?
I might try a work around by using a git cloud with the Logseq data to open on a 2nd and/or 3rd display.
I guess you are on macOS?
It is still broken in macOS Desktop 10.9. See my workaround comment in this github issue. You need a second graph to make the select graph UI show up and then you can use a trick using Shuft-Click to make it happen.
see also: Shortcut for New Window gone?
In short
  1. Open a second different graph as new window
  2. Change that graph to your main graph or open a new window of the original graph using Shift-Click.
Why this workaround?
  • The menu Shortcut simply does not trigger the new window (bug), → see the ticket for progress.
  • The current graph does not show up in the selector.
Using Shift-Clicking the logseq URL of a different graph in the contents page in the right sidebar was working to open the target of the link in a new window as well as far as I remember, but this is also not working in 10.9 anymore.
  • Clicking these links should open a target (page) as new Window in a different graph in , when not already open. Shift-Clicking is not helping there. You need the link for a common page like logseq://graph/my-logseq-graph?page=Contents
  • This is opening the other graph when the target graph is not open and can be changed back to the original graph there in the selector.
  • maybe this is an OS problem and the shortcut tries to open a second window on OS level and this is now blocked by macOS. Missing console events leaves this unknown for me.
I’m on 3 displays with Linux Mint.
I’m used to Google Docs opening a browser tab, using all 3 monitors for document management.
If Logseq is able to view from more than 1 screen, that makes it easier.
linuxmint@linuxmint:~$ inxi -Fxz
System:
  Kernel: 5.15.0-122-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
    Desktop: Cinnamon 6.0.4 Distro: Linux Mint 21.3 Virginia
    base: Ubuntu 22.04 jammy
Machine:
  Type: Desktop Mobo: ASRock model: H470M-HVS serial: <superuser required>
    UEFI: American Megatrends v: P1.10 date: 01/11/2021
CPU:
  Info: quad core model: Intel Core i3-10105F bits: 64 type: MT MCP
    arch: Comet Lake rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
  Speed (MHz): avg: 3203 high: 3700 min/max: 800/4400 cores: 1: 3561
    2: 2686 3: 1912 4: 3038 5: 3511 6: 3638 7: 3700 8: 3578 bogomips: 59197
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: NVIDIA GK208B [GeForce GT 710] vendor: ASUSTeK driver: nvidia
    v: 470.256.02 bus-ID: 01:00.0
  Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: nvidia
    unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia resolution:
    1: 1024x768~75Hz 2: 1024x768~75Hz 3: 1024x768~60Hz
  OpenGL: renderer: NVIDIA GeForce GT 710/PCIe/SSE2
    v: 4.6.0 NVIDIA 470.256.02 direct render: Yes
Audio:
  Device-1: Intel Comet Lake PCH cAVS vendor: ASRock driver: snd_hda_intel
    v: kernel bus-ID: 00:1f.3
  Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  Sound Server-1: ALSA v: k5.15.0-122-generic running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: yes
  Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    vendor: ASRock driver: vfio-pci v: N/A port: 3000 bus-ID: 03:00.0
  IF-ID-1: br0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
  IF-ID-2: virbr0 state: down mac: <filter>
  IF-ID-3: vnet0 state: unknown speed: 10 Mbps duplex: full mac: <filter>
  IF-ID-4: vnet1 state: unknown speed: 10 Mbps duplex: full mac: <filter>
  IF-ID-5: vnet2 state: unknown speed: 10 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 2.15 TiB used: 1.12 TiB (52.3%)
  ID-1: /dev/sda vendor: Intel model: SSDSC2KW240H6 size: 223.57 GiB
  ID-2: /dev/sdb vendor: Intel model: SSDSC2BW120H6 size: 111.79 GiB
  ID-3: /dev/sdd type: USB model: TYPEC3.2 JM583 size: 1.82 TiB
Partition:
  ID-1: / size: 218.51 GiB used: 151.53 GiB (69.3%) fs: ext4 dev: /dev/sda2
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 2 GiB (100.0%) file: /swapfile
Sensors:
  System Temperatures: cpu: 47.0 C pch: 51.0 C mobo: N/A gpu: nvidia
    temp: 61 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 395 Uptime: 4d 16h 39m Memory: 15.51 GiB used: 11.91 GiB (76.8%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 3272 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
