Option to disable auto-close parenthesis?
A huge +100 to allow disabling this feature. It is obtrusive and the single worst part of Logseq.
Asking users to re-learn how to interact with a text area in a product specific way that caters to a poorly implemented feature isn’t strictly the best way to grow the user base.
I support (and have asked elsewhere) this feature because it’s current imposing on users is not useful on so many levels:
  1. it is not Context-Aware: If I only want to close a previous opened character from the auto-close map, put it only once there, not twice. Then, if I select some text and type a character from the Map, enclose the selected text with that character, as expected;
  2. I want to be able to edit the whole auto-close sets map and keep what I find useful and remove what I find frustrating and not useful to me. For example, I would like that [[ to trigger not [[]] but []( [[]] ) so I can have a standard Markdown Link that also uses the Logseq Link Feature. After Auto-Completion, keep the cursor between the first [] just as with Links and then, if I type Enter or Tab (interchangeably) it should jump in between the Logseq Page Link square brackets;
  3. I find it frustrating to use Logseq with Text Expanders when trying to Expand some text that has in it whatever characters from this auto-closing map because it ends up a messed up text with no sense. See Anybody using Espanso with Logseq? If so, how do deal with "replace" strings that contain [, (, etc -> which auto-complete the closing corespondent?;
Bottom line: I want to be able to Independently Toggle OFF the auto-closing characters feature and the Selected Text Enclosing feature as well as UNITE the Auto-Close feature with some internal Text Expanding feature so I can define not only what character sets will get auto-closed but what the end-format will look like just like with text expanders.
Plus one to an option to disable autopairing. I am most frustrated by backticks; I frequently go back to surround existing text with backticks and have to do a lot of extra arrow-keying and deleting. When I enter text, I basically always hit backtick to close the inline code style anyway; it’s faster than moving my fingers back to and from the arrow keys.
I would like the feature removed. It just gets in the way. If nothing else, a setting, turned off by default, for autopair.
Really, just let us disable it. I love logseq but this frustrates me so much that I’m thinking of switching
Adding more squeak to this wheel. I would go so far as to say this feature should be disabled entirely, and only brought back online once the necessary changes are made to make it optional. Clearly this is a low priority fix, so disable the feature now, then let the solution come when it may.
Leaving us in this state is bad for all.
I am okay with this feature and am surprised that people would look for an alternative to logseq because of it. I suppose that everyone has a different threshold for unacceptable inconvenience.
Among the problems listed above, it’s also incompatible with markdown codeblocks, which is a sore point for a markdown editor.
I emphatically agree with this request. The current implementation is clunky and distracting.
It frustrates me to no end. I’m taking notes on coding and also pasting links all the time and this makes it so difficult to just recopy the links I’ve already pasted in. It makes not using the mouse practically impossible.
I feel like this means the parenthesis zombie should be more or less cleared up by now.
I’m liking LogSeq so far, but autopair is doing my head in.
Please implement a config option to disable this functionality. Thank you.
YES! Please allow config to disable this! :slight_smile:
Hello,
please see Auto-Pair Toggle and Custom Map - #5 by FlorianF
I’m using a text expander to work-around this annoyance of not having a way to do a custom “auto-pair” mapping in Logseq …
I also found this highly irritating. But luckily this is easy to fix, you just need to comment the respective pairs in the source:
diff --git a/src/main/frontend/handler/editor.cljs b/src/main/frontend/handler/editor.cljs
index d2fe00cdf..4cf50385b 100644
--- a/src/main/frontend/handler/editor.cljs
+++ b/src/main/frontend/handler/editor.cljs
@@ -1555,18 +1555,18 @@
 ;; For example:
 ;; 1. Which file format is it, markdown or org mode?
 ;; 2. Is it in the properties area? Then we can enable the ":" autopair
-(def autopair-map
-   "_" "_"
+(def autopair-map {})
+  ;;  "_" "_"
 ;; ":" ":"                              ; TODO: only properties editing and org mode tag
 (def reversed-autopair-map
2.39.5
Thanks for giving a solution to this long-running issue, which annoys me every time!
(I have to adjust my workflow to avoid it, or swear, and delete forward)
However, although the code change is “easy to fix”, working out how to re-build Logseq, make a new package, etc is not.
So I would suggest that it is still important to roll this into the official distribution as a user option.
Thanks
