Visual chart for queried data
First, I’m newbie. Not a coder also.
But I really love to use logseq to show and visualize my data (which I done in some other application including ClickUp, Larksuite). Now I really really want to do it on Logseq.
I search for plugin that can help visualizing my data in graph but can’t and hard.
Including:
  • logseq-chartrender-plugin: I don’t know how to start to make the chart, the only thing in the instruction is modifying indicators. Moreover, this plugin cannot install directly on marketplace, I have to manually install it and not sure it work or not.
  • logseq-property-visualizer: It use the chartrender above, and I think that that plugin is not work, so this plugin cannot work. It can show the table but chart.
  • Logseq Plugin Query Chart: Not work! Even I do exactly the example they give. If anyone already test and used it, please help.
Maybe kind of late now, but you could try this one
This similar request of mine might help:
Forgot to update.
This should be the solution
A simple non-plugin alternative (also works on mobile): Charts from queries
