Feature request : Creation of Folders and subfolders, will make knowledge management more feasible
The Problem
  • We can’t create sub-folders inside folders. Thus all pages are stored in pages folder only, which make clearing the clutter difficult. Deletion of unwanted files.
  • Pdf linking and highlighting creates extra files. If some file name is changed, it doesn’t update the links and reference is lost.
  • Crystallization of thought files not possible due to linkage updation problem, and no specific folders.
  • Though I have tried creating folders inside pages folders, but all the pdf highlights, other assets linked are suddenly not accessible.
  • is the path correct error is shown.
  • also due to no folder categorisation, I can’t keep related resources files together. Retrieving becomes difficult if link is lost.
I would love folders, and even better could we have it so namespaces are basically folders?
So in Logseq the page Books/Dune would be pages/Books/Dune.md rather than pages/Books.Dune.md
Agree - however I’d personally tweak the feature request to this:
  • We need the ability to easily rename files
  • Create the ability to query files/assets only, by file attributes: type (pdf, doc, wav, etc), modified time, etc
This will allow for a document library, organized/filtered by LogSeq tag and by file attribute, to be embedded on any page.
Personally I hate the folder schema (files can only be in one “folder” at a time) vs. a tag schema.
Another upside of a folder structure is being able to have different git repos for different spaces. This would make team collaboration easier.
This is almost a deal-breaker for me! It’s too bad because I thought I found the right tool. I need a rich folder structure to sync with Obsidian.
Please see Proposal: Changing How Namespaces Function in Logseq.
It’s basically the same idea. Storing namespaces with folders.
It’s on the team radar, but it will take a while
What do you think about moving Proposal: Changing How Namespaces Function in Logseq from #bug-reports to #feature-requests? It might be losing visibility for being in the wrong forum category.
See also [R] Move assets to dated subfolders for an example of how to move assets into subfolder based on creation date
I agree with you. But in my workflow, I work with imposed organisations with specifics folder structure (my clients, team), I work with OmniFocus, and need to work with the same structure of folders, everywhere, otherwise it would be a mess. It’s already happening, because i am creating my PKM in Logseq since a few days (newbie :smile: ).
It would be great to have that option too in Logseq. Because I could use folders (for external needs) but at the same time, using logic of Logseq PKM because I prefer. For the moment, I have separated the 2 worlds because that. It’s a labyrinth …
Based feature request.
I also need and am proposing something similar:
Has this function been added? I still can’t create folders. I would like to have all my Raindrop imports in one folder, Readwise imports in one folder, all my notes in one folder, all my ToDos in one folder, etc.
I agree, for interoperability with Obsidian this feature is clearly needed.
+1
It was actually my first thought, once I opened LogSeq the first time, like “where are my shelfs/ loose-leaf binder / quick stapler, something to order my idea sheets & whiteboards”.
I imagine, to use LogSeq for game development as a intern “project’s - wiki“.
I have a large (more than 10GB) set of folders and files, MANY layers deep, in a primary Dropbox Folder. My primary means of accessing them is with the notebooks app for ios. I also access them with emacs, where I use org mode. I thought it might be cool to access the files with a graphing notebook. I opened the folder with Obsidian - no problems, but there was no structure for the graph, without making it. Obsidian won’t sync vaults larger than 10GB. I thought I would try Logseq, since I like open source better. Ugh - just an infinite list of files, not folders, and compaints about duplicates (I have more than one script folder that contains a file called “scene1.md”, for example). This is completely unusable for me. I will no go away from Logseq, until folders are implemented.
