Hi
I have already found the following information:
- The Logseq documentation page on advanced queries: https://logseq.github.io/#/page/advanced%20queries
- The reference to the data schema: logseq/db_schema.cljs at master · logseq/logseq · GitHub
- and the link to http://www.learndatalogtoday.org/
This is useful information but I am still not able to write the queries I need.
What I am still missing is:
- Information about which attributes belong to the same element (i.e. share the same element ID).
- The information which values of which attributes in turn contain a reference to an element ID of another element.
- And I still don’t understand certain parts of the syntax.
My question on the first two points is:
Is there any documentation about those aspects?
On the last point, let me give you a concrete example:
The following query basically works fine:
{:title "⭕ open TODOs in the journal ..."
:query [:find (pull ?h [*])
[?h :block/marker ?marker]
[(contains? #{"TODO" "WAITING"} ?marker)]
[?h :block/page ?p]
[?p :block/journal? true]]
:result-transform (fn [result] (sort-by (fn [h]
(get h :block/priority "Z")) result)))
:collapsed? false}
I thought I understood how this query works and tried to enhance it.
I want to exclude all the TODO and WAITING blocks that contain the keyword “subtask”.
So if I have the structure …
- TODO main task one
- TODO main task two
- TODO subtask 2.1
- TODO subtask 2.2
… I want the query to return only the two “main tasks” and NOT the subtasks (2.1 and 2.2.).
So I added this part to the query:
[?h :block/content ?content]
(not [(contains? #{"subtask"} ?content)])
which leads to this query…
[?h :block/page ?p]
:collapsed? false}
But this query is not working. I assume there are some very basic things I still don’t understand.
SUMMARY:
- Is there any documentation about which attributes belong together to which elements?
- Is there documentation on which attributes contain element IDs as values?
- Can someone help me with the query above?
Thanks
Chris
